Hello Friends. Greetings to all of you
C80100-Turnigy 180KV Outrunner motor I do think that using an electric bicycle.
I think this is to use the engine.
[url = http://postimage.org/] http://s10.postimage.org/hgm6vw6e1/HXT80_100_A_1.jpg [/ img] [/ url]
[url = http://postimage.org/] hosting images [/ url]
The engine's features are as follows.
Model: TR80-100-A
Turns: 6
Maximum Power: 7000W
Resistance: 17ohm
Idle Current: 3.5A
ESC: 150A
Input Voltage: max. 48V
Kv: 180 rpm / V
Weight: 1812g
Shaft: 12mm
Voltage Range: 20-48V
Non Load Current: 3.3A
Equivalent: 60-80cc Gas Engine
While the engine maximum power is able to provide a power of about 7000W.
There are some issues I was wondering. We would like to consult.
This is how efficient the engine for an electric bicycle?
I think a gear ratio of 1:10 to put the engine speed. In this way, reduce the engine speed chain wheel to transfer power system, I think.
This engine is an engine that is designed for aircraft. Therefore, there is the engine through the Hall sensor. I wonder if you insert the motor hall sensor adding a bike engine Do I see any problem in the study?
Model: TR80-100-A
Turns: 6
Resistance: 17ohm
Idle Current: 3.5A
ESC: 150A
Kv: 180 rpm / V
Weight: 1812g
Shaft: 12mm
