boostjuice
Metallover said:That should be able to be changed. The shaft on normal outrunner is attached to the bell with a grub screw, and can be slid back and fourth on the bell. I don't see how it would be much different on the monster.. Even if it was held in place by something other than a grub screw, a little machining would probably fix the problem.recumpence said:So, I wonder why no-one has pointed out the obvious.........
There is no shaft protruding out the mount side. That is something we need for belt or chain drive. This is the problem with the Plettenberg Predator........ :?
Matt
The very fact there's a circlip on the shaft means it's highly likely the shaft is an interference-free/low-interference fit. Easily replaceable by a longer one, or potentially just offset the existing one up and out of the mounting end. It's not like its needed to be protruding at the prop attachment end.
