major
I finally got around to trying to charge an EnerDel 12S module using two BC168 chargers. I am aware that that charger is not isolated from the power supply on the most negative cell. So I used a separate power supply for each BC168. And even went to a battery supply for one of them. So the inputs to the two BC168 units were definitely isolated. The module was sitting at 4 V/c and well balanced to within ~30mV/c.
BC168#1 connected to cells #1 thru #6 and works fine by itself. BC168#2 connected to cell #7 thru #12 and works fine by itself. But when I use them together, cells #6 and #7 show 4.2 Volts while the other 10 cells show 4.0 Volts. All cells show 1.0A in discharge mode. The same voltage reading occurs when in the balance mode. Obviously there is crosstalk between the two BC168 even though they are isolated (except for cell#6+ and cell#7-).
And idea why this happens? I really wanted to be able to use the two BC168 together on the 12S modules but can't tolerate the .2V offset.
