Hi,
I'm in the process of building a mobile robot to demonstrate an agricultural spraying use case. The robot has two motors that drive the skid steer (6v @ 2A each) and a water pump (12v @ 4A) taken from a car windshield washer pump. I have an Arduino equipped with Wifi, GPS and a few other sensors (IMU, LEDs) which is providing PWM signals to a cheap-o 4-axis DC motor driver.
The whole setup uses a smartphone power bank (1 x 5v, 5000mah) for the Arduino and its electronics and a pack of 4 x AA NiMh batteries for the 4-axis motor driver.
Its a pain dealing with many batteries, have no ability to detect charge levels, and in general very messy with lots of cables. I've also noticed that the powerbank for the Arduino is unable to supply 1.5A consistently with WiFi running and GPS running. Not a long term solution...
I was thinking it would be fantastic if a single battery pack could manage all the power reliably for me.
I recently found and broke open a 10,000mah Li-ion power bank and found five 2Ah cells connected in parallel. I'm now thinking of rebuilding a single rechargeable battery pack from these batteries!
Is there anyway I can achieve what's in the diagram using off-the-shelf electronics from Digi-Key or other supplier?
What I want as features are:
- Uninterrupted power for motors and Arduino from battery and recharge at the same time from wall supply (like a smartphone)
- Same battery should provide stable 2A @ 5V to the Arduino and electronics without drops while the motors are running
- Same battery should power the three motors irrespective if one, two or three are running at anytime.
- Battery should provide feedback on its charge level
Is this even possible? I'm no expert in battery electronics and afraid that I might create a fire if I'm not careful
. Given that the battery cells will drop their voltages very low due to the high loads, I'm even wondering if the Li Ion batteries will survive or be able to recharge at all.
Many commercial robots like Roomba and Drones from DJI and 3DRobotics have internal rechargeable batteries but I'm not sure how they manage power the motors and electronics at the same time. Any help is much appreciated!
