RLT
Just a quick update on the 120-130V BRUSHED motor controller conversion:
If you have worked with the Yi-Yun / TNC Scooter controllers, you know about that irritating, even startling, Arc- spark when you make the last connection. It is normal on the 48V and lower controllers, but it can be actually DESTRUCTIVE on 100 Volts or higher.
Four times I have vaporized a solder trace or connection or a thin copper PCB trace, even without a actual short, just due to arcing, power surge , something. Fortunately, it hasn't destroyed components, but I have had to run a couple of jumpers, or rebuild / reinforce some of the solder busses, and paint on some lacquer insulation. But even doing that doesn't stop the next 'weakest link' from blowing the next time I do a hookup.
I think I have the problem solved though:
What I did is take one of those Harbor Freight three dollar car battery cutoff switches and parallel it with a couple of 10watt / 4.7K power resistors. Make sure the switch is off when you make the final wiring connection; The resistor lets the controller partially power up 'gently', then when you cutout the resistor with the switch, there is no arcing, no vaporization of connections.
Don't know if that is the optimum ohms for it... It was just what I had handy, and it seems to work fine.
I also did some more component substitution: Replaced the seven 330 uF caps with four 680uF 200V 105 degree ones:
http://beta.mouser.com/Search/ProductDetail.aspx?R=381LQ681M200J022virtualkey59850000virtualkey5985-381-200V680
They fit inside the original controller box just fine (if you put them on longer leads so that you can lay them sideways). They even provide a little more power and make for a much neater configuration.
I also replaced the 'Frankenresistor" with a couple of 2.2K ohm 5 watt aluminum housed power resistors in series. (the reason I used the two X 2.2K is that is the closest I could come to the calculated 4.4K I needed.). That works OK, but it gets a little hotter than I'd like.
I think I'm going to replace it with a higher watt 4.7K ohm aluminum housed resistor. That will hopefully make it run a bit cooler, and maybe let me run at 144V.... SOMETHING... I don't know what, is cutting out if I go over about 135V. Not burning out; It works fine if I drop back down under 135V.
Will post some photos when I get a chance.
