Talon said:
ElectricGod said:
You will need a new motor controller. The existing controller won't handle the voltage and it's locked down to a specific speed anyway...which you are intending to exceed a good bit. Those motors are tiny geared hubs, so who knows how much more wattage you can pump through them before they burn out. Worst case, give it a shot and replace it with a better option when it dies.
I'd go with the PowerVelocity 6 fet controller. You can find PV on endless sphere. He will get you set up with a very small controller that will be very reasonably priced and far more powerful for lots less money than URB-E charges for their puny controllers. After that, it will require some rewiring to adapt the URB-e systems to work with the new power source.
That down tube will hold quite a lot of batteries if you remove all the other stuff in it. Use the smaller square frame for your controller.
Are you talking about this controller? I don't see a 6 FET controller http://powervelocity.com/index.php?id_product=54&controller=product
PM him directly on ES. He doesn't list all of the controllers on the web site. That was the 12 fet controller. I have 2 of those, but they are overkill for your needs. He sells them with the IRF4110 mosfet. I have been pushing Vadym to use the AOT290 mosfet instead of the IRF4110. It's higher wattage, is faster switching on and off and has less internal resistance. It's generally a much better mosfet than anything else out there right now. Anyway, he's specifically making the 6 fet controllers with the AOT290's. The 6 fet controller with AOT290's in it should be capable of about 2000 watts which is more than enough for your needs. I've never cracked open the high wattage URB-E controller, but I bet it's at most 500-600 watts. IE: Waaaaay over priced, way UNDER capable and lame all at the same time.
