ChristianR
Hi,
I have a 36V 12Ah LiFePo4 battery, but I would like to use it for running a 24v motor + 24v controller.
Most of the time (when I am using a 24V battery), I measure a maximum power <800W, and intensity max < 35A.
I can't change the controller.
So is it possible to use the 11 pin plug (available for the balance board charger) of my 36v battery and to connect 2 wires only on it, to obtain 24Volts? (pin 1=gnd + pin 8)
- may it dammage the battery if I use only 7 cells during discharge (7x3.6 =25.2V) among the 10 available cells (36V) ?
- may it damage the balance plug or thin wires?
thanks
thanks
