steveo
This is how i currently configured everything for my 66v 20s 5p pack; but i may be upgrading to 45amp Anderson power poles....
Disadvantages (currently)
- I hate using this 12 guage wire i used, its no the silicone type so its harder to bend,
as well as this wire is only 12awg & not the 10awg i would prefer
-also deans connectors are generating a bit of heat
Solution I'm thinking of..
-I've purchased 6m of 10awg silicon wire!! to start & try out!
-Ive purchased 300 45amp anderson powerpoles 150 black 150 red with pins + tool
I'm looking to do the same type deal if i do more packs but i would like to use sodderwick to parallel the cells & then attach the 10awg & Anderson connectors at the end.. I have currently some .125" sodderwick in front of me .. Will this be sufficent say to carry 50-70amps+ or is this a bad idea? My intentions are to be able to cap the ends of the packs with the factory dewalt black side caseings ( the ones used for balancing only***)
thanks in advance
-steveo
thanks in advance
-steveo
