Ok so I threw the battery together real quick and I also took the other battery out of the bike to make room, here are the pics
13s 17ah battery
Frame nice and dirty just the way I like it! A little rust already forming! love cheap steel
Here is the old setup, the new setup is going to be a much tighter fit, lets hope it all goes in
Had to move the controller for now
Used two pieces of 16awg wire twisted together for the series connections this pack will likely be drawing 15a most of its life if it works
Quickly soldered them all
put a 12awg turnigy negative on
attached it to the BMS
then another that will power the controller
Put a 12awg positive leading to my controller also
soldered all the BMS balance leads
lightly taped things away from one another hoping to protect against shorts
decided to put the bms on the end since the frame is kinda skinny. This will likely be on the top of the frame near the key switch when installed
neaten up some of the wiring (im no perfectionist)
need to add a switch to turn the pack on
this loop turns the pack on when you short it
OMG it actually puts out voltage!
forgot to solder the charger negative so threw that in real quick
Looks like its just about done
grabbed the charger I was using for 12s and adjusted the pot to put out 54.4v should be good I think
Now I just have to cram it all in the frame and hope it doesn't blow up!
