vertical play in tongsheng tsdz2 bottom bracket
c3xxk
hi, i'm experiencing some vertical play in my bottom bracket. it's perpendicular to the length of the tongsheng tsdz2. i'm wondering if other units have this issue as well, and if so how to fix it?
attached is an animated gif to illustrate the direction of the motion.
note: you might have to download the animated gif before viewing so you can see the 'motion'.
here is also a flat image showing the direction of the play.
i tried a few combos:
1) two copper washers + lock ring
2) one copper washer + wave washer + lock ring (didn't fit)
3) two lock rings (didn't fit)
4) two copper washers + wave washer + lock ring (didn't fit)
5) one wave washer + lock ring (original setup)
unfortunately none of these combos reduced the movement. its not that there is too much space along the length of the bottom bracket, so it doesn't seem like it matters how many washers I put along this way. the play may be within the gearing inside the bottom bracket itself?
thanks for your help!
That could just be bearing play as the original bearings are not the best quality. I listed the numbers for replacements on the non-hub motor section, which is probably where you should place this also.
HF1216 The one way needle bearing
609RS Roller bearing, even available in ceramic.....
30 CSK-P The Sprag clutch/bearing
