Hi i have been building this battery over the last few weeks. Its a 12s 36v 15ah lifepo4 and so far its been testing perfecly fine. I have been getting 560wh at a 10a load.
The bms is connected up properly now this is just an older photo. The over charge and balancing is working well.
I went to charge it last night and it wouldn't charge (through the bms), so i tested the voltage across the sets of 3 which should give me 9.6v each and they did apart from one. One set of three was only giving 6.4 which would indicate a cell at 0v.
By tapping the offending cell it would come back up to 3.2 volts again and the pack will charge and operate as normal and by tapping it or moving it, the voltage will gradually drop to 0v after a minute or so.
There is no sign of energy being used when this happens, no heat, sparks or any reaction of any sort.
The connections between the batteries are solid and i would expect to see open loop if something had been disconnected but my meter has not shown open loop in any case.
I know i will likely have to replace the cell, it would just be nice to hear other peiples thoughts on whats actually going on here.
Thanks
Thanks
