teslanv
SO I have spent a bit of time here and on the ebikes.ca simulator (http://www.ebikes.ca/tools/simulator.html) and I think I understand the basics of how all of these concepts relate.
Here is how I might try explain this to a "NOOB" :
Concept 1: A Direct Drive Hub is configured with copper wires in a variety of options. Depending on the size (diameter) of the copper wire, how many strands of that wire, and how many "Turns" those wires are wound around the armature, you will get a certain kV of motor. - 1kV = 1 RPM per Volt of applied electricity.
A Common ebike direct drive hub might have a kV of 9, so that when a battery of 48V is used, that motor will have an unloaded RPM of (48X9) = 432 RPM
Concept 2: A Hub Motor may be rated "1000W", but can usually accept much higher wattage, as long as the temperature is controlled. - Various methods of cooling are possible, the most simple being to drill holes in the side covers to allow air ventilation.
Concept 3: Size Matters - at least with respect to Wheel Diameter- wheel diameter makes a BIG difference in the speed of your bike.
Given the Hub Motor example above at 432RPM (48V) the standard 26" Mountain Bike Wheel diameter would provide an unloaded speed of 33.4 mph and a 20" Diameter Wheel would provide an unloaded speed of 25.7 mph, but would have more torque than the 26" Diam wheel. 700C or 29" Wheel would have even higher speed than the 26" Wheels, but less torque.
Concept 4: Voltage = Speed - If you want to go faster, get a higher voltage battery. If the 26" MTB Wheel and 9KV motor can go 33.4 mph on 48V (unloaded), then the same motor and wheel can go twice as fast (unloaded) on twice the voltage, so 96V = 66.8 mph (unloaded)
Concept 5: Voltage alone won't get you the real world speed you desire, because factors like mechanical and electrical inefficiencies, rider & bike weight, slope of incline, and most importantly wind resistance will all work to slow you down from your unloaded speed. - to compensate for the non-efficiency-related factors, you need more torque or current (More AMPS) to overcome these factors. So a high voltage (and high Unloaded RPM) system will struggle to overcome the factors listed above, unless you have the torque (and thus thrust) required to offset them. However, higher current also comes with the cost of higher temperatures, and at some point all motors, when provided with too much current will overheat, and bad things start to happen. Usually the insulation melts off of the phase wires and cause an electrical short, which will pretty much kill the motor.
Concept 6: - Thicker (heavier gauge) wires will help to keep the system heat down. If your Motor's phase wires are small (16ga or 18ga - higher number = smaller diameter) it will help to replace the phase wires with a thicker (12ga or even 10ga if you can fit them) to keep the phase wires cooler, longer.
Concept 7: Hub motors like to spin at their nominal kV rating. When they are spinning slower (like starting off or climbing a hill, loaded down with weight) they are not very efficient, and the power (Watts) being supplied to the Motor is turning into heat, rather than motion (speed). The goal is to operate the motor at it's peak efficiency (usually around 80%) which is typically between 1/2 to 2/3 of it's unloaded RPM.
How might you explain these concepts differently? Anything you would want to add?
