Forget about it, you won't find firmware with a bootloader; it's now just spare parts...I accidentally bricked my Votol controller and desperately need your help to recover it. I performed a full chip erase via ST-Link, which completely wiped the factory bootloader.
Unfortunately, I have two of these controllers,Forget about it, you won't find firmware with a bootloader; it's now just spare parts...
No, you can't read it with ST-Link or anything else. The STM32 chip can't be read. It's programmed into the chip's hardware, not even into the software. Try reading it with ST-Link, and the copyright protection system kicks in and wipes its memory, unfortunately...If so, could I read it from the controller using an ST-Link?
El que tenga el bin SW 2.32 por favor que no lo cambie , eso es potencia brutal , el que quiera aclarar dudas y aprender de verdad escríbanme a mi WhatsApp , mi número es +18077896504Hello. Does anyone have the firmware file for the Votol EM200/2SP controller? I accidentally uploaded the firmware from the Votol EM100 controller.
Olviden al vino ese y escríbanme , actualmente trabajo en la siaecosys aquí en EEUU en Votol , mi número es +18077896504Hello everyone on this forum, I created this topic with the intention of helping and spreading knowledge. I had a lot of difficulty finding solutions for my Votol EM50SP, but now I've found what I needed through a YouTube channel called VINO - Votol Monitor Z.
I will be providing a link to my Mediafire with a pack containing .bin, .ini, .apk files and versions of the Votol software. If this helps you in any way, then this post was worthwhile. Cheers.
MediaFire
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
www mediafire com /folder/ea7roialtzie3/Mega_Pack_VOTOL_Software
Escríbeme que te voy a configurar esa controladora para que veas la calidad hermano , mi número es +18077896504Hello everyone,
I hope someone can help me.
I have an original VOTOL EM150 controller (old version, not EM150-2) installed on my electric ATV.
I am looking for:
1. The correct PC software for the original EM150 controller.
2. A download link for the latest software (Windows).
3. The correct USB programming cable for the EM150.
4. A reliable place to purchase the programming cable.
If anyone has the software, a wiring guide, or a purchase link for the correct USB cable, I would really appreciate your help.I have already restored the controller and it powers up correctly. I am now trying to diagnose the throttle wiring and would like to connect the controller to the PC for troubleshooting.
Thank you very much!
Creo que esa viene con la SW 2.34do you have any firmware for votol EM80
controller?
Escríbanme para configurarle esoHelp needed! Brick recovery dump (128KB) for Votol EM-100S / EM100-4 V4.1 (72400S UART)
Hi everyone,
I tried flashing the firmware files from the community "Mega Pack", but they are only 48KB-60KB application-only files without the bootloader code, so the MCU cannot boot up. The controller is currently dead and has no serial communication at all.
However, I can fully access the processor via ST-Link using SWD pins, and the chip is unlocked and writable. I just need a full 128KB raw binary flash dump (.bin) extracted from a working unit starting at address 0x08000000.
Here are the exact specifications of my controller:
If anyone has a .bin file with bootloader section please help!
- PCB Markings: EM100_v4.1 / EM-100S 60V-72V
- Black Plastic Casing Sticker: Voltage: 72V | Angle: 120 | Model: 72400S
- Original Box Label: EM100-4/72V | DKYS/72400S/UART
Thank you so much in advance!
