I have purchased 3 WarP 11" HV motors that are in Jim Husted's shop now. I have some the test results from the Net-Gain factory. They tested them at ONLY 72V and maximum 590 Amps.
I asked them why they don't test them at higher voltages. Here is their answer:
...so I made a graph based on the available data:
I have no idea if this graph will prove in real-life but I can't do better because of the lack of information.
My motor will probably perform better than that because Jim is building in some of his performance parts.
My biggest question is if the motor will have any power above 5000 RPM. A experienced electric motor designer from a big company in Croatia told me that the rotor field has to be weakened to have some power in the upper RPM band. Since there are no controllers that control the stator and rotor windings separate, I guess that I have to gear the car to drive 150 mph at 5.000 RPM. Or is there some other way to squeeze more power out of them at high RPM's?
Btw. The car will have two motors, every will have it's own Zilla Z2K EHV and a 370V nominal, 2000Amp capable pack. Direct drive (LSD)
Mate,
That question comes up every time..... The dyno is only capable of 72 volts..
Volts and RPMs are nearly linear, so doubling the voltage will double the RPMs. Torque will remain the same if the amps don't change.....
George
