Guys,
I had my first ebike breakdown in 4,500 miles. I hit a few puddles from melting snow here in New England and after 5 miles or so I lost power abruptly. With the wheel off the ground the motor would turn the wheel at about 10 mph max with a very jerky vibration. I pulled the 5-pin hall connector apart and saw the inside was wet. I dried it as best I could and things partially improved but still could not get solid power.
Had to ride 5 miles with 408 motor cogging torque & 25 lbs battery into a 30 mph headwind back home ( :x :x )
I let things dry out overnight and today everything was normal during a short test ride.
I would like to carry a small can of spray compound that could repel small amounts of water off of electronics. In the old days I used WD40 to dry wet ignition wires in my car and that worked pretty well. Any ideas for a spray for ebike electronics, wiring connectors, etc? I could try WD40 but am curious if there may some product specifically intended for this purpose.
Thanks for any ideas.
regards,
Bill
regards,
Bill
