Watts happening?
Neophyte
Today I observed an interesting phenomenon that I'm hoping the more experienced and knowledgeable folks on this board can, and will, explain.
Firstly...
I have an e-bike that consists of a Trek Navigator as seen here..
http://www.trekbikes.com/ca/en/bikes/town/recreation/navigator/navigator_3_0/#
Coupled with an eZee kit as seen here…
http://ebikes.ca/store/photos/eZee26R-B.jpg
Powered by a combination of myself and a 48V20Ah battery pack as seen here…
http://www.bmsbattery.com/48v/249-48v-10ah-lithium-ion-electric-bicycle-battery-pack.html
And on my latest ride I noticed something that I hadn't noticed previously given my particular riding habits coupled with some seemingly erroneous assumptions.
And what am I talking about?
Well, a little something that strikes me, for one, as very strange.
And I'll start by stating that I generally ride with the system turned on from start to finish and there are times when I will ride for distances approaching 100 km. And usually the cruise control (a 3rd party system add-on) is set at between 22 km/h and 25 km/h. The Cycle Analyst watts reading being usually in the 200W area on a fairly calm day. This is with no pedalling and on flat and level ground.
Wanting to get some exercise on my rides, however, I'll pedal for a while and then stop pedalling and let the system take over for a while. And in the past when I have pedalled I've had the gears set fairly high such that my cadence is low to medium which has the effect of my immediately feeling the weight of the bike. That I'm putting in a significant effort and dropping the watts reading by, perhaps, 100W. The speed of the bike picking up by maybe 2 km/h.
On my latest ride, however, I did something different with that something being to pedal in a lower gear than usual such that my cadence was higher than usual. This had the effect of my not feeling the weight of the bike anywhere near as much as when I'm using a higher gear and, additionally, had the effect of impacting the watts reading to a far greater degree than usual. Dropping to as low as 50W.
I couldn't then, and can't now, fathom this.
Pedalling at a faster pace in a lower gear and not feeling the weight of the bike so much has a greater impact on the watts reading than does pedalling at a slower pace in a higher gear and feeling the weight of the bike such that I have to rest far more often.
And now that I've discovered this I, of course, know how to maximize battery efficiency.
But it does strike me as hugely odd.
Can anyone explain?
If you get rid of the motor and battery, you will feel even less weight, then you will be able to pedal the 50 watts of assist that they give you. :mrgreen:
Sort of, but not very well...
Power is force expressed over time.
Force is the change in acceleration over time - if you're keeping a steady pace, it just means your "change in acceleration" is nullifying the deceleration due to friction and wind resistance.
That means the power you're producing is both a function of how hard you're going, and how fast you're doing it. Do it faster, or do it harder, and power increases.
In circular motion, power = torque x rpm.
If you drop your torque, but increase your rpm, then you can have exactly the same power. If you drop a little torque (don't pedal as HARD), but due to that fact, can pedal a lot FASTER, then you can increase total power.
Have a look at this dynograph for a Dodge Stealth:
The blue line is the power generated, and the red line is the torque.
You can see that if you spin the engine faster, while torque remains the same (Say 4200 - 5000rpm), the power keeps increasing.
However, once you're past peak efficiency of the motor (After 5000rpm) you can keep spinning the motor faster, and for a little while, your power will still increase (Up till about 5500-5700rom), but torque will fall off. Keep going, and the power will fall off too, and there's no point revving the engine any further - you're losing power by doing so.
It's the same with you. When you pedal slowly, but at a very high torque (Very hard to pedal, say 4200 on the graph), you're not making peak power, despite putting in maximum effort. If you reduced the torque, but pedaled faster (say 5500 on the graph), then your effort feels lower, but the total power produced is higher.
Does this make sense? I warned you this wasn't all that well explained :p
Basicly, you just discovered one of Lance Armstrong's tricks, pedaling in a gear just a bit lower than you thought was perfect produces more power to the wheel with more comfort to the rider.
Almost everybody pedals in the wrong gear, that is, about one gear higher than they should be in. That incudes the pros. The too high gear seems better because you have to focus on your pedaling more in a lower gear, faster cadence. It's harder to pedal smooth in the lower gear. In the sprint of course, you go high gear and just try to break the pedals off, so it's not intuitive to pedal in such a fast cadence naturaly, and nobody does it unless they train themselve to pedal higher cadence.
Mountain bikers use low gears and fast cadence more, so they may get more used to it. I never pedaled fast cadence myself, till I got on mountain bikes. I just pedaled inefficeintly, but had lots of power due to decades of snow skiing.
To run a motor with less watts, you choose a throttle setting, and then pedal up at least 1 mph more speed.
Since I don't have an e-bike (yet) and like to go cycling in the mountains (my av. sunday afternoon trip
is 700m height difference, over about 35 km) I know what you're talking about.
As a person you have a certain leg-rpm and leg-force that you're most happy with. I can go up the
hill at 8 kmh in a high gear and kill myself, if I go down 1 or 2 gears the same 8kmh up the same hill
is easy.
I think as a person you have an efficiency curve. Your legs are much happier in the lower gear, therefore
you're outputting more watts. Especially a high gear with lots of force (low rpm) is very tiring for the
legs... When I buy a bike i always pay attention to the gearing to make sure it allows my legs to
operate in the low force/high rpm region they're most happy at.
When my knees "went bad" a few months ago from arthritis I went to 155 mm cranks and had to go to lower gears. It really does seem to generate more power and less tiredness especially over 20 miles. I still can barely walk when I get off the trike at first, but it is muscle pain rather than joint pain, and goes away after a while. Low gears and short cranks really helped my knees!
otherDoc
like mentioned before, we instinctively gear to big (slow frequency) because we stupidly think that if we turn our legs "slower" we will be less tired...
There is actually some true in this BUT there is also some question of efficiency. A good trained guy should pedal at about 90-100 rpm. If I remember well Armstrong was peddling at 110rpm.
You can try on a home trainer...110rpm is crazy fast!!!
I mentioned "trained" because there is the trick. Someone not trained will actually be more tired with high frequency pedaling at same performances. Why? again because our shitty brain ^^ Your pulse will go higher, your respiration also so concretely your complete body will work harder and you'll be tired.
BUT if you ride often, even with little power, trying to keep a high frequency 80-90rpm will after a short period, let's say 6month from "no trained" to "trained" (with at minimum a bi-daily exercise of 45min/1Hrs) you will feel HUDGE improvement in your performances, as much as you will probably re-consider to drive an ebike under 25Km/h ;)
I tested this theory on a friend of mine who was a daily commuter. It works.. the only thing is to understand what's efficiency and finally understand that our body is definitively a machine :) I also used a heart frequency watch to help him monitoring his power.
There is also a big improvement in stress and fatigue on the articulations, less torque = less stress = easy on the articulation. But really, at the beginning it's so lame to pedal so fast and to go so slowly... I cannot tell you the numbers of people which will look at you with a mix of surprise and an deep pity ^^
Gruß,
H.
I'm a few years younger than Lance, but I grew up in the same town, and rode the same roads he did. Conventional wisdom amoung cyclists seems to be 90rpm cadance as the ideal, but growing up here, I had more than a few people tell me to gear down and try 100-110. I did and learned to ride that way.
Its likely Lance's influance on the local bike comunity there, and his wisdom being passed from one person to the next. Or it might have been wisdom that came from someone else, and he learned it here too.
Higher cadance has a drawback, you're not using your legs as hard, but the action of moving your legs faster raises your heart rate and metabolism, so you're burning calories faster. Ultimatly, that cuts the distance you can ride. but thats the hard wall where your body quits, and realy only important on Very long rides or races. you will likely find your legs stay fresh longer and you can go further on a 20 - 40mile ride depending on your aerobic fitness.
Neophyte said:
... And in the past when I have pedalled I've had the gears set fairly high such that my cadence is low to medium which has the effect of my immediately feeling the weight of the bike. That I'm putting in a significant effort and dropping the watts reading by, perhaps, 100W. The speed of the bike picking up by maybe 2 km/h.
I have no idea what's going on. The picture would be a lot clearer if you provide the speeds for the 2 scenarios, preferably on the same stretch of the road.
1) Higher gear, lower cadence: speed and power as reported by your CA
2) Lower gear, higher cadence: speed and power as reported by your CA
Even better, repeat the test on a fixed range loop (2 km?), on the same road, in the same direction and immediate back to back tests. Reset your CA before each test and report average speed, total distance and total wh consumed for both scenarios.
Firstly...
Can anyone explain?
Cadence............................................................................................
Physics
The work required to move a bike down the road is measured in watts. To define it very simply:
Watts = Torque x Cadence, where Torque = Force x Distance; or how hard you press on the pedals multiplied by the number of times per minute you apply this force.
Two cyclists, Bob and Bill, weigh the same, have identical bikes, identical aerodynamics and are riding next to each other at the same speed on a flat road. Because they are riding the same speed and we’ve controlled all the other variables, they are performing the same work, ie, riding at the same watts. However, Bob is mashing at 70rpm while Bill spins at 110 rpms. Bob’s pedaling style dictates that he press hard on the pedals with each stroke. But he does so less frequently than Bill, who is pushing lightly on the pedals but much more frequently.
Physiology
Low cadence cycling requires us to push harder on the pedals, but what does this mean at the level of our leg muscles? To generate that higher force contraction, your leg muscles must recruit more fast-twitch muscle fibers vs slow-twitch fibers.
Slow-twitch fibers:
Primarily burn fat for fuel, an almost limitless supply of fuel for even the leanest athlete.
Are very resistant to fatigue: they are built to go and go, all day.
Recover quickly when allowed to rest.
Fast-twitch fibers:
Burn glycogen for fuel. This glycogen is stored within the muscles and is in relative short supply, about 2000 calories for a well-trained, well-fueled athlete.
Fatigue quickly, are NOT built to go all day.
Take a long time to recover before they can be used again.
Matches
CyclingPeaksSoftware.com developed this analogy. I think it’s a good one, but I like to elaborate a bit. Imagine your legs are a book of slow and fast burning matches. The purpose of training is to increase the size, number and flavor (ratio of slow and fast) of your matches, depending on the demands of the race. Sports requiring short bursts of speed favor athletes with lots of fast matches. Endurance events favor slow matches. You can use either match to do the work of racing but the total number of matches in the book is finite. And once you burn a match, it’s gone - you can’t get it back.
Now, back to our discussion of cadence. You are riding on a flat road, approaching a hill that will take you about a minute to climb. You will likely do one of four things:
Shift to a gear that feels comfortable and/or powerful for you. You feel good when you climb at 60-70rpm so you do that, shifting to the middle of the cassette.
Climb at 60rpm since you showed up to the ride with a 21-11 rear cassette.
Say “The hill will only take me a minute to climb. I don’t want to lose any speed so I’ll hop out of the saddle, stand up and hammer up the hill. I’ll recover on the decent.”
Shift into your 25 cog and spin up the hill at 85-90rpm.
Option #1: Low cadence = high force = high fast twitch recruitment = burning matches that you may need towards the end of the run. Forget “feels” powerful. Power is watts to the wheel, period. If you can climb a hill at the same speed (equal watts) at 60rpm or 90rpm, choose 90rpm. Conserve your fast twitch fibers so you can recruit them later in the run.
Option #2: See Option #1 and always bring enough gears to the race. In my experience, the only people who attach sexual competency issues to the gearing on their bike are folks who don’t climb. I have (no lie) six cassettes hanging in my garage that I swap on and off my bikes according to the terrain of the ride. I have everything from a 27-12 to a 19-11. You can flatten any hill if you have enough gears on your bike J.
Option #3: Standing = power spike = high fast twitch recruitment = you know the drill. From riding with a powermeter for many years I can tell you that if you don’t have a meter it is VERY difficult to stand in the saddle and not toss out huge watts for a brief amount of time. It might “feel” ok, but chances are very high that you just burned a few matches with your little burst.
Option #4: Bingo! Spin up the hill, burn slow, not fast matches so you can use those matches on the run, burning the last one as you cross the finish line.
What is the optimal cadence?
Ok, so I’ve sold you on the value of high cadence vs low cadence. But what is the optimal cadence? In my experience, most athletes should ride at a cadence of 88-95+ rpm. A few notes here:
Notice that this cadence is right in line with an optimal running cadence. I believe it is hard to run off the bike at 90+ rpm if you’ve been cycling for hours at 80rpm. You’re asking your legs to make a huge adjustment, in addition to the difficulty of transitioning from cycling to running.
More experienced and stronger cyclists will be comfortable within a wide range of cadences. When I began cycling, anything under 88rpm felt like mashing, while 95+ felt too fast. I was always searching for that right gear. Now, after many, many miles, I can ride equally comfortably at 78-82 or 100-105. My tool kit is much larger (see below).
Cadence and Training
Some coaches prescribe low cadence intervals as a method to train your body to push harder on the pedals. However, consider the importance of specificity: if you want to run longer, run longer; if you want to swim faster, swim faster; if you want to ride the bike farther, ride the bike farther. If you want to ride the bike faster at 92rpm, then ride the bike fast (high watts, ie greater work output) at 92rpm.
Having said that, both low and high cadence work are useful for increasing your “cadence comfort,” or your comfort within a wide range of cadences. By this I mean you have strong, resilient, well-adapted legs that can handle a broad range of cadences, including that high force/high wattage contraction that may happen if you run out gears, decide to climb out of the saddle, etc. You have a large tool kit to handle a broad range of conditions.
The most common tool is a period of low cadence intervals fitted into the early season. My guidance:
Beginner: useful tool early season for developing sport-specific strength and “cadence comfort” quickly in their cycling careers.
Intermediate: useful early season, see above. However, after 4-6 weeks of low cadence intervals, transition to lactate threshold intervals at normal, time trial cadence. Reserve low cadence for fartlek-style training - grind up a hill at random to build or retain this cadence comfort.
Advanced: high watts at race specific cadence is more useful. These athletes have already developed cadence comfort and a period of low cadence intervals is, I believe, often an unnecessary step. I reserve low cadence work for:
Fartlek, see above.
The last hour of long rides, to force recruitment of fast twitch fibers when they are already on the edge.
Athletes training with power: the ability to measure watts while cycling at very low cadences creates possible exceptions to this guidance. The power-training athlete can truly turn his bike into a piece of gym equipment and is, I believe, more justified in adding low cadence intervals to his training routine.
In summary:
Focus your training to develop speed (wattage) at your race-specific cadence - the cadence you plan to race at. My suggestion is 88-92+ rpm, with weaker, less experienced cyclists targeting the high end of this range.
Supplement this race-specific training with informal low cadence/out of the saddle work to build this resiliency above and expand your range of comfortable cadences. See my guidance above for how to build low cadence intervals into your particular training season.
Bring the proper gearing to the race! And when in doubt, bring more gears! I think a compact crank is an excellent tool for all cyclists to consider.
Bring these fast, strong, resilient legs to the race. Put them on a bike with the proper gearing. Exercise smart, disciplined pacing and climbing skills to limit the number of matches you burn on the bike course, burning that last match at the finish line!
Thank you for the replies.
Was great to be able to relate to what folks had to say in general as regards personal riding experience and cadence issues, etc. and equally great to understand the physics, etc. involved in what I observed.
All input was greatly appreciated.
These boards are an awesome resource for sure.
But once again I can't express emphatically enough the shock I experienced as I watched the watts reading dropping under the circumstances talked about. It's only been three months since my first e-bike and I had assumed that when I pedalled forcefully on this machine, such that I seriously felt the involved weight, that I was contributing, at that point, maximum watts.
Little did I know!
And now that I know better it shall be done.
No nore wasted effort.
Thanks kindly once again.
