So I recently posted here asking for some advice on a LiPo pack and controller. Settled on a 59.2V nom 16S4P pack made up of 16 4S hard pack LiPo bricks paired to a Lyen 9-Fet controller.
After some sweat and soldering, managed to get everything all wired up and ready to go. Stupidly I assumed the hall and phase wires for the motor matched colour to colour, so I just hooked it up that way and in my eagerness took it for a test ride. What I know now is that I had 2 of the Hall wires revered (Blue to Blue and Green to Green when it should have been Green to Blue and Blue to Green), and 2 phase wires mixed (should have been either yellow and blue switched, or green and blue).
So anyway, in my eagerness to test it, everything looking good, I gave it a bit of throttle. It was loud and a bit rough, but again very stupidly I just brushed it off as being the motor groaning under the higher voltage and current. Well... seems that wasn't the case. As the speed maxed out (admittedly slower than my 36V pack would take me), the groaning stopped, so I assumed it was alright. Slowed down, started up again through the same loud groaning and then suddenly the CA is reading 8000W being used, then the motor simply cuts out and I guess the term 'cogs' would be correct, as it provided a ton of resistance pedaling back with the controller off. When I got back the motor was extremely hot (too hot to touch), and the hall wires were equally hot. The controller also had a significant amount of heat coming off of it.
Now after fixing the wiring problems, the controller still reads 8000W or so when turned on, and I get absolutely no response from the motor.
So my question is... did I kill the motor, controller, or both... If there's any other information any of you might need to help diagnose, or anything you think I should try and report back on, I'm all ears.
