What all does Factory Reset reset?
ClimberBill
100 µW
Utah
Trying to use a Bafang front motor G320.250 with a Eunorau kit that originally had a Shengyi motor. I need to change the Speed Magnets or Motor Poles settings. BUT this controller has me locked out of those Advanced Settings. All I see there is Max Speed and Assist Levels.
What will a FACTORY RESET do? Will it clear the Lock Out as well as resetting all the other parameters? I’m scared that it might reset parameters, but I’ll still be locked out of Advanced Settings.
Your question hasn't been answered, so I guess nobody knows for certain what factory reset will do to your particular display. If you are going to factory reset, best record all current settings. I speculate all settings and codes will default to the original ones, and if you don't know the original code for Advanced Settings, you'd be stuck again.
To get into Advanced Settings it accepts 1919 which is typical for Bafang.. The problem is there’s only two parameters in there, (and the Reset). I’m locked out of pretty much everything in the controller.
I thought certainly someone here had done it.
