chrashing
I was looking at toggle switches to put on the lead of the 48V battery to the 30amp controller. Found a 30amp switch, but then noticed it was for 12 volts, and see that the current capacity is reduced as the voltage increases. Beginning to look like I need a very hefty switch to handle all this current. So now I'm thinking that I should ask for info on how this is normally done....
Is the kill switch usually on the battery power line (high current)? Or is the kill switch put on one of the controller circuits, like to disconnect the throttle, so a low current switch can be used to stop the the motor? What is a good way to do this?
