parmenps said:
how am I connect these batteries: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19716
on the mac 500w
what do I have to buy for it
Thanks for your help
You would be better off to get the 5S packs, less wiring.
Connect 3 in series for 15S and another 3 in series and connect the 2 15S packs in parallel for a total capacity of 16S.
You have to make up your own wiring harness.
Seriously though I think the emissions free pack should be the way to go, a lot less complicated, a lot longer life for a commute, no fire risk, no newbie mistake risk.
But those are the probably the best assembled packs you can buy at the moment. Ping batteries are good, but they are not able to supply a lot of current for long.
yes you're right I'll go buy this battery then http://www.emissions-free.com/catalog/i29.html
because the battery should not stand out on me bike
You would need at least 2 x 48 volt 20ah ping batteries in parallel to run the mac 1000 watt 8T to reduce stress on the battery, where the emissions-free packs are much better for small packs and high discharge.
If you want a lot of range the ping batteries would make more sense and would be more battery for less money, but you would need 2x 20ah packs, and they weigh 9.9 kg each for the 48V 20ah. and go for 2x 5 amp chargers to charge in half the time.
