Hi everybody,
I have plans to buy an electric conversion kit for my bike this or next week, but have just found out that there are too many different kits out there...
Basically I want a kit for offroad use, I don´t care if it´s not high speed because what I really need is a climber that can move 100kg (220lbs) through steep hills (some of them around 12 or 13%).
In fact, my idea is to use the motor only when I need to climb so I would use my legs for the rest of the time. If I could reach an autonomy of 25-30 miles that way it would be perfect!
After reading the Mathieu Beauregard´s review about the Wilderness Engergy kit (http://pages.videotron.com/guizzmo/), I´ve thought the WE BL-36 brushless kit could be a good buy as it´s only $450, then I could remove the SLA batteries and install a much lighter Nimh battery, boosting the power from 36V to 48V as Mathieu did.
I could buy 40 Nimh cells of 1.2V 10000mAh to build the battery for about $290, so the entire system would be $740.
I can only see one problem with this kit: it can only be mounted on the front wheel. As I want the motor to climb I guess it would be better on the rear wheel... but not sure if that´s really a problem.
What do you think? Is it a good idea or should I go for a different kit?
