Trying to get an idea of what ranges you guys are getting. I seem to get very bad range. With my 48volt (12s4p) (8 5000MAH 6s packs) 20 amp hour setup on a full suspension mountain bike, I am only getting 20 miles from my batteries. Although I was told I would get 40 miles. It seems pretty consistant that I get about 20 miles and my voltages are around 3.7-3.8.
I guess I drive full throttle alot and have to brake pretty often being that I live in the city. I also do not pedal very often.
I was wondering if you can list what your specs are and how you drive and how many miles you get out of your batteries.
Also, if I double my battery capacity, can I assume my range will be double even with the added battery weight?
If I use a higher voltage, 72 volts or 96 volts, will my range change?
Is it possible to get 40 miles out of my 12s4p setup without pedaling or little pedaling? How should I drive?
