so here the 2 motors i'm testing, the left is MAC, rated 1000 watt, on the right BMC rated 600 watt, but is capable if doing 25% more rpm's then the BMC
ever since the begining, i've always had the impression that i need a 48 volts system to get a bigger kick. but now i'm not so sure, i'm now trying to figure, what exactly is the system most optimized without just wasting heat, with ecospeed's controller and motor i've managed to get usages of 2.6 ah per km (i'm measuring that way cause i wannna calc the range of the battery), using infineon's and mac's i got 1.9 and with bmc i got 1.6 km per amp. but ride times also got to 35 even 31 minutes respectively. but still all of this with 48 volts and 25-30 limit.
but will i feel the difference with a 36 volts system? will it meaning anything, if not can i shift all my focus on 36v battery packs, and focus on amps alone?
