psychonurse
Hi, I will be making a bid on a abandoned e-bike at a auction.There is no model of the bike or rear hub motor on it. It's a 18 speed mountain bike. No battery, don't know if anything works or not. Any advice appreciated
That's the bike from my post right? i was so sad i couldn't bid on it since i live in NYC. at least an ES member got it.psychonurse said:Good call on that one. It was in fact the one with the funky panniers on it. Well I took a gamble and bid $180 and won the auction. It is a Chinese made bike. Has some good products in the build. RST CAPA T-8 Suspension forks. Gossamer FSA pedal system. I took it to a electric bike shop and they said it all worked great. It has a rear 36v 750watt rear hub motor. I need a battery unfortunately. Any suggestions on buying a 36v /15 amp lithium battery. I guess I will go with Ping unless you guys can give me a better option. Thanks.
it's defe not factory made ebike, like i said, it has a "champion" sticker on the wheel right? if so i'm pretty sure it's a yescomusa kit, just check out that yescomusa ebay link i sent you. Look at the motor pictures.psychonurse said:Yes, It was really odd that they answered that persons question saying it wasn't a electric bike. Perhaps since it didn't have a battery they decided to label it as just a bike. I'm happy they did. The only markings I see on the motor is stamped into the metal casing of the motor. xF 40 1101 0695. I also see a sticker attached stating 36v 26". So you think it is kit someone put together and not a factory made E-bike? Interesting. I can't wait to get it back to send some pictures to guys for more ideas of what I have. Thanks for the tip on the ping I will check that out.
.Shouldn't I be concerned that the label on the controller says. 36v 22amp I believe
