svt/r&d
Hub Motor out there and why???
Thanks for the great responce, this will be used on a ebike, seems like there would be more to choose from out there?lazarus2405 said:First, I agree completely with everything Toorbough ULL-Zeveigh said. Decide what you want to use the motor for, and then we can point you in the right direction.
That said, there are a few basic generalizations I can make for you:
Crystalyte hub motors are often considered among the best. You'll find that the majority of hub motor users on this forum use them. They have a good reputation, and are the technically most understood motors on the market.
Within the Crystalyte motors, there are two families: the 400s and the 5300s (also called X5, 5000, or Phoenix motors). The 400s are lighter and less expensive but cannot handle as much power as the X5s. If you want to run more than 1500 watts of power, the X5 is the way to go. If you will be running less, then the X5 will only be extra weight and a 400 will be your best bet.
Within each motor family, there are different "windings", which describes how the copper wire in the motor is wound. A lower winding generally corresponds to a higher speed (that is, with the same voltage the motor will spin faster, but it will require more current to generate the same torque as a higher winding), and a higher winding corresponds to more torque (on the same voltage it will have a lower top speed but generate more torque with the same current). Note that all windings within a family have the exact same magnets and the exact same amount of copper wire, and thus they are equally "powerful".
There is another motor which folks on these forums seem to like, not made by Crystalyte, called the Puma. Think of it as being between a 400 and 5300, with more torque than a 5300 but a lower top speed. It weighs less but can fewer watts (that is, power) than a 5300.
Remember, torque corresponds to better acceleration and hill climbing ability.
Also remember that your motor's performance will depend on what feeds it, meaning the motor controller and your batteries. Power = Current * Potential, which is watts = amps * volts. More amps will give you more torque. More volts will give you both more torque and a greater top speed.
Your best bet is to decide what you want your "cruising" speed to be and then maximize your torque to that speed. This will give you the best acceleration and hill climbing at the speed you desire. These two calculators can help you:
http://ebikes.ca/simulator/
http://www.kreuzotter.de/english/espeed.htm
svt/r&d said:Thanks for the great responce, this will be used on a ebike, seems like there would be more to choose from out there?
svt/r&d said:Hi, well this will be a new type of recumbent, very lightweight and aero. it's only 6miles to work and less for most stores etc unlike the L.A. madness lol it's flat and not alot of wind on the main drags except for the sandblast days lol, pack will be a123 cells it's all about bike and golfcart lanes here![]()
