beaker said:Can the stock 9 gear derailer and shifter be adjusted to work with 5-6 or 7 gears?
andy1956 said:deralier should be able to be adjusted to accomodate less movement.
sheldon brown said:Indexed Shifters These need to have the spacing of detents ("clicks") to match the system they'll be used with. This usually goes along with the correct number of clicks -- though a shifter with an extra click also can work, as long as the spacing is OK. (Friction shifters have no compatibility issues, they work with everything.)
wturber said:Many people may find imperfect index shifting unacceptable. But I've spent about 99% of my riding time using friction shifters, so the imperfect operation doesn't bug me at all.
Chalo said:wturber said:Many people may find imperfect index shifting unacceptable. But I've spent about 99% of my riding time using friction shifters, so the imperfect operation doesn't bug me at all.
Noisy chain and sprocket operation, stuttering, and skipping are more serious than a mind it/don't mind it issue. It greatly accelerates wear and tear on the components when the derailleur is constantly guiding the chain to an in-between position that doesn't correspond with a sprocket. Lightly engaging the shift-assisting features on the chain and sprockets without actually shifting gradually wears those features away. In a worst case, the chain can skip or drop off when you're standing on the pedals to get up to speed, and a crash results.
Friction shifting allows you to make minor trim adjustments for quiet, smooth operation. Incorrect index shifting doesn't. That's why early index shifters came with a friction mode that could be enabled in case of system damage that misaligned the index positions from the sprockets.
999zip999 said:Dnp has a 9speed 11t freewheel . I would use a friction shifters old school.
wturber said:My system wasn't noisy, didn't stutter, and only skipped in two middle to low gears - which was the "imperfection" that I was dealing with. And that skipping had always gone away with one click up or down. After that, no noise, stutter or skip.
That begs the question of how things could run quietly given the spacing differences.
