You can't get one, yet.iperov said:I just want kit based on turnigy etc motor, gearbox, etc, just "plug & play" middrive kit on MTB !
Dauntless said:Well, you offer him 450 watts while the Turnigy has the allure of seeming to promise 10-15 times that. If you can get it without blowing everything up.
Plus the Turnigy's sure to seem to be the cutting edge. Or maybe the bleeding edge. Even the BURNING edge. You just have to remember that if you're making sport with RC motors on your bike, you're playing with fire. Right, Mr. Sauty? Maybe 450 watts shouldn't sound so bad to a beginner.
Thud said:For the record, Will burned (shorted) his motor out on the track after this fire took place....the fire was a misconected battery & large enough wire & conectors to create a fire. (I was there shortly after this happend...not during the actual fire) Nice scare photo though.....Cleary a good photo of the worst case senario playing out in real life....I have dead shorted much larger lipo packs without issue(asside from KFF & exploded connectors)..but again I have a fail point designed into the packs to prevent this sort of thing.
Also, Mr SoSauty is still using & enjoying Hi output Turnigy NANOTECH batteries on all of his hub powerd e-bikes at the race track will great effect.
That said, I won't recomend any stock RC motors to anyone who doesn't have an advanced working knowledge of rc batteries & components, gearing & reductions + strong fabrication skills & a knowledge of where to get all the stuff for such a build.
I am also Not promoting any rc controllers for e-bikes.....they are unforgiving unless you have a well tuned COMPLETE set up that is bicycle specific. Nothing "off the shelf" is going to work for bolting onto a Joe-blow bicycle.
I have too many PM's from guy's using small motors, over geared & confused why it burned up or poped the controller.
All this from a guy who actually builds & sells RC reduction units to forum members.....there is no perfect set up yet.
T
nice guarding middrive clubrscamp said:don't even think of getting an R/C system.
rscamp said:I don't have an R/C drive (yet), but based on my experience selecting motors and gearing for large helis and knowing the differences in motor load vs speed between driving a propeller in air vs a high inertia load such as a bike with a human on it, I would say this:
1. If you don't know where your bike and performance expectations will put the motor on its efficiency curve for the bulk of the time then don't get an R/C system. If you don't even know you need to worry about this, don't even think of getting an R/C system.
2. If you want lots of 'pulling' torque at low throttle settings, you are going to have a bad time.![]()
