Just thought I'd explore the topic of positioning the kill switch. In the situation where your controller decides to go full throttle, because the throttle got unplugged or whatever, where would the best place to put the kill switch be? I've heard that unplugging the battery could kill the ESC due to the voltage spike caused by the motor's inductance so I guess unplugging the motor sounds like the other option by default. But would unplugging one motor wire work with an ordinary one wire switch? Or would something like a three-pole on/off switch be needed so you could unplug the motor in its entirety?
Any ideas on a good way/place to wire the kill switch?
Anyways, I've unplugged the motor's wires a few times during initial testing during the run-aways and it didn't seem to cause the controller harm and it worked, but I don't know if it's as effective during higher current loads like say if you had a bike capable of 50 mph but you're in a situation where 20-30 mph is safe and cutting out the wire at 35 mph might have a lot of current flowing if the controller goes full throttle.
