marshy
marshy said:Does anyone happen to have corresponding manufacturer's performance data for model (SWXH http://www.szbaf.com/en/product_detail.asp?ProductID=513).
I'd be very grateful for someone to do a sanity check on my reasoning of which Bafang SWXH motor configuration to get. Here's my situation:
- I intend to use a SWXH rear motor. I haven't been able to find model performance data specifically for the SWXH but I suspect they are similar to the SWXB range (covered well in this thread).
- need a genuine assistance motor (I want to do lots of peddling, but need more speed in headwinds - common in my neck of the woods)
- I like to cruise between 25-32 kmh, typically ~30 so I want useful assistance up to and beyond low 30's. Stock Bafang configuration seems to be designed around 25km/h max
- I'd like the motor to work efficiently in my normal cruise speed range
- I intend to comply with the Oz 200W limit. In practice I intend to select a "200W" motor from the range, plus run at motor's rated voltage (36V = my battery pack voltage).
- 700c wheel
So, 700c wheel, >32km/h max assisted speed and assuming the top 10% of the motor speed range isn't usable, then I need to aim for say 35km/h no load speed, i.e. or 265rpm for 700c wheel.
Looking at the data for the SWXB, the 36V, 200W, 20inch wheel version has no load speed of 262rpm. Would that be a sensible choice, or am I violating the natural of things in some way by running a "20inch" wheel version on 700c??
(a second choice might be the 22inch/36V/200W -> 240rpm version. This would give me a little less top speed (maybe 29km/h in practice?) but perhaps lead to a little less stress on gears? Not sure how available the 22" version would be)
All the other 36V/200W versions are too slow or too fast (rpm).
Would be grateful for any opinions. Hoping to order a motor early next week.
