Indubitably
- Joined
- Jan 9, 2010
- Messages
- 126
I recently had one of the cells on my lifepo4 motorcycle battery go poof, and when I opened the thing up I noticed that the shunt resistors on the BMS seemed somewhat less than impressive. I know these things are only built to take 3 or 4 amps, but we're talking gnat's ass surface mount resisters. At any rate, long story short, I just don't really trust these prefab lead acid replacement batteries, especially considering the premium you pay for them, so I want to build my own. I'm thinking 4 10ah headway cells in series should do the trick, but I don't know which BMS to use.
What I'm looking for: A BMS so bullet proof that I can just build-it-and-forget-it. Ideally I'd like to be able to install it and never have to manually balance the cells again, but I get the impression that no bms is going to be able to do that.
What I'm willing to sacrifice: This isn't a exactly a massive battery, so I can afford to drop a little more cash on oversizing the cells, and I only have 4 cells in series, so the BMS's cost per channel can be pretty high.
What do you guys think? Am I over thinking this? Would I be better off just going back to a decent AGM lead acid battery. After all, at the end of the day, I am mostly looking for reliability and low maintenance.
