White Molex Connectors??
So I picked this tool SN-28B has 3 slots, only 2 listed, 2.54mm 3.96mm.
http://www.ebay.com/itm/SN-28B-Pin-Crimping-Tool-2-54mm-3-96mm-28-18AWG-Crimper-For-Dupont-JST-SM-/131590895643?hash=item1ea36db81b:g:0BIAAOSw9N1VzAUZ
The same tool below, just a different title is all. With these slots 2.0mm 2.54mm 3.96mm.
I think those are the correct tool, and much cheaper. This ebike hobby is expensive so when I can save $20 on a tool its well worth it.
This is the one I bought - http://www.ebay.com/itm/SN-28B-Pin-Crimping-Tool-2-0mm-2-54mm-3-96mm-18-28-AWG-Crimper-Dupont-JST-/281772294704?hash=item419af00230:g:5ZoAAOSwDNdVzAUw - will have to find a local source for those connectors now.
Because all the TNI-U crimpers on ebay
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=XH2.54+PH2.0mm&_sop=15
say this
TU-190-08 XH2.54 PH2.0mm DuPont Terminal KF2510 Crimping Tool Pliers
So I am thinking its 2.54mm and 2.0mm are the two terminals in the TU-190-08 tool.
Found some useful info here
http://www.ebikes.ca/learn/documents.html
under Miscellaneous Connectors: JST-SM Series
http://www.jst-mfg.com/product/detail_e.php?series=238
http://www.jst-mfg.com/product/pdf/eng/eSM.pdf
Hope my tool works on them
SN-28B Pin Crimping Tool 2.0mm 2.54mm 3.96mm 18-28 AWG Crimper Dupont JST
Recieved my Plato SN-28B tool today and it works good on the ebikes.ca "Bag of Connectors"
Upon first use, I would recommend this tool. After 50 or more crimps, it might be a different story.
With the V part of the tool, I place the U of the connector upside down into the V, I press the tool in a few clicks so the connector holds, place the wire in and make sure the connector is straight up and down, and the I part of the tool comes down and crimps it solid.
I have messed up a handful trying to solder and use pliers, only messed up ONE female connector using the tool.
I placed the female piece too far in and it crimped the wire but also a wrong spot.
The tool itself has some weight to it, solid clicks and the handles are solid and strong.
I just need to find someone on eBay selling the same connectors.
Just went through a similar search/order. Now waiting on parts to be delivered from Aliexpress.
https://endless-sphere.com/forums/viewtopic.php?f=2&t=79638
Includes links for the pins as well as the 6 pin connectors.
