redorblack
- Joined
- Sep 26, 2009
- Messages
- 142
I asked the owner of the company I got my front hub motor from if he could get his supplier to make him a hub motor that took a standard Shimano freehub. I'm perplexed why no one is doing that already. It seems like rear hub motors are still 30 years out of touch with this... a freehub with cassette is a much stronger setup than a thread on freewheel hub. The bearings are further outboard on the freehub vs the freewheel and you could then use any modern cassette/indexed shifters you wanted.
Is it because you need to pull the axle to work on them? Maybe it's just easier for manufacturers to machine a thread onto their hub motor body therefore they don't want to bother with adapting to modern components?
Even if they were forced to make a slightly smaller form factor motor like a bafang only a bit skinnier, I think it would still be an advantage. I know I want to be able to run my shimano cassettes (9 speed) on the back of my trikes. I can't run a front hub motor since my front wheels are single side mounted axles and have integrated drum brakes.
Is everyone just copying everyone else and that's the problem?
