OK, so I haven’t flown my tin foil kite yet, but Tesla said that more radiant energy is evident at higher altitudes. In the mean time, I will have to go with my cursory experimentation.
A true story.
I hung a 2’ x 5’ piece of tin foil from a bookshelf in my second story bedroom. I connected one wire from the center of the foil to the positive end of a small capacitor.
Outside, I pounded a 1 foot long piece of iron rebar into the ground. I attached another wire to it, ran it up the side of my house, into the window and attached it to the negative side of the capacitor.
After 12 hours I measured the voltage on the capacitor and it had gone up, not by much, but it had gone up.
I then wondered if radiant energy was AC. Tesla liked AC so I hooked a rectifier up to the wires and sure enough, the capacitor started filling much more quickly.
Turns out radiant energy is AC!
After a week I measured the amount of energy I had collected in my capacitor and extrapolated that with that amount of tin foil it would only take 20 to 25 years to recharge 1 AA battery.
Beyond that I extrapolated that if you had a about 6000 square feet of tin foil surface you could recharge a AA in about one day, give or take.
Conclusion:
If you had a really big back yard and a very large roll of tinfoil, you could power your bicycle on radiant energy as long as you ride no further then your wires can reach.
This spring I am going to fly my tin foil kite, watching out for the power poles of course! :wink:
