BiggKidd
I know size and weight are the two big negatives. Then again neither are all that much more for LifePO4 than they are for L-ion. Maybe 20-30% larger and heavier for LifePO4 than L-ion. The really big difference between them is the number of cycles. L-ion seem to top out between 800 and 2,000 cycles where as LifePO4 last upwards of 6,000 to 10,000 cycles. Price wise I just don't see a lot of difference in the two. 20 to 30% weight and size savings for less than a quarter of the lifespan it just doesn't make good $ sense to me. Maybe you guys can explain it to me! But for me in my way of thinking the LifePO4 have it all over L-ion in performance because they have a fairly small operating window of about 1.5-2 volts @16s in comparison with L-ion's window of about 10 volts. In other words my (48V) 105AH 16s1p LifePO4 at mostly full where I like to charge to is at 53.5V down to about 52V about as low as I like to take them. Where as a (48V) L-lion uses it's full range from about 53 volts down to about 43 volts. The power and performance is so much better with that flat curve from 53.5 to 52 it's almost steady throughout compared to L-ions 53 to 43 where you get a HUGE power loss in the bottom 2/3rds of your charge!
What say you?
What say you?
