lawsonuw
Ok, just bought this motor used from another forum member. Initially it'll go in my bike as a hub motor, but my final goal for this bike to is to have a bottom bracket drive. So, this means I need to know what the inside of this motor looks like!
First pic shows my motor cracking tool of choice. Needed this chepo flywheel puller because the bearings are a tight fit to the axles. Removed the screws on the cover where the wires came out, used the puller on the OTHER side of the motor to open a gap under the cover, inserted spacers to keep that gap, then moved the puller to the cover pulling on my gap to get the cover off. Beware the bearings will slip with a loud "ping" making it sound like something broke
Next for a look at the guts! here you can see both covers and the top of the brush holder. 10-pole radial flux motor with two brushes, and rare earth magnets, not bad.
Here we see the back of the commutator.
And a Closeup of the brush holder. Everything looks good here!
Here u can see the brush holder when it's out, plenty of length on those brushes. This also gives a peak at the commutator. It looks well worn but serviceable. I'll turn and polish it when I mod a side-plate for BB drive.
That's all for now folks,
Marty
Marty
