Hi again guys
I wanna test the temperatures between the original phase wire and then another original phase wire that has 4awg cable crimped onto the wire around 15cm outside of the motor.
Im just curious to see the temperature difference. I will use 2 separate temperature probes that are connected to my ANT BMS and can be monitored on my phone.
Would the actual movement of the motor have any problems since 2 phase wires are original and the 3rd phase wire have such thick cable.
The lengths of all 3 phase wires is about 1 meter, from the motor to under the front forks because I mount my controller on the outside of the frame.
Thanks!
Thanks!
