ZeroEm
So solar has a different frequency than Natural Gas? I always thought it was the equipment that set it regardless of what was producing it. So what is the frequency of Coal?
Hillhater said:We do not know which plant went down first ,...timing for the Hornsea plant has not been released....you are just repeating media reports....
.......unless you have evidence of course ?
Exactly what misinformation do you think i posted ?
Hillhater said:Can you join the dots yet ?
ZeroEm said:So solar has a different frequency than Natural Gas? I always thought it was the equipment that set it regardless of what was producing it. So what is the frequency of Coal?
Yep. It's set inherently by the grid itself - and occasionally by another reference signal. RE providers often provide "ancillary services" which include frequency regulation. (Note that they don't even need batteries for this; the large capacitors in the RE inverters have enough storage to do this.) This service adds out of phase current to the grid in an attempt to maintain frequency in the face of natural gas plants dropping off the grid (as happened here.) Solution - add more RE providers who can provide ancillary services.ZeroEm said:So solar has a different frequency than Natural Gas? I always thought it was the equipment that set it regardless of what was producing it.
Ian, with reference to the UK blackout the exact time of the frequency dip is well known (16:52pm) .Ianhill said:The small fluctuations in the 50/60hz background hum of the grid is so unique over a small period of time it can be used in a court of law to prove time and date of indoor recordings, current tech renders this old school method quite useless but it's still something that can be replicated most indoor recordings carry this signal on the audio and with access to grid frequency data it can be date stamped accurately.
Hillhater said:Ian, with reference to the UK blackout the exact time of the frequency dip is well known (16:52pm) .Ianhill said:The small fluctuations in the 50/60hz background hum of the grid is so unique over a small period of time it can be used in a court of law to prove time and date of indoor recordings, current tech renders this old school method quite useless but it's still something that can be replicated most indoor recordings carry this signal on the audio and with access to grid frequency data it can be date stamped accurately.
What is not being released yet is the exact time of the fault on the Hornsea system . All we know for sure is that at
17:00 Hornsea was unavailable to supply ( that is just the start of a normal 30 min billing period)
https://www.rechargenews.com/wind/1838142/technical-fault-at-worlds-largest-offshore-wind-farm-before-uk-blackoutOrsted said it is “fully confident” there will be no repeat of the fault that took the world’s largest offshore wind farm offline, contributing to a massive power outage that hit the UK a week ago.
A statement on Friday from the Hornsea 1 owner gave its first insight into the role of the project in the blackout, the subject of an urgent inquiry by UK TSO National Grid which is due to present its early findings to Britain’s power regulator Ofgem today.
a project spokesperson for Hornsea 1 said: “During a rare and unusual set of circumstances affecting the grid, Hornsea One experienced a technical fault which meant the power station rapidly de-loaded – that is it stopped producing electricity.
“Normally the grid would be able to cope with a loss of this volume (800MW). If National Grid had any concerns about the operation of Hornsea 1 we would not be allowed to generate. The relevant part of the system has been reconfigured and we are fully confident should this extremely rare situation arise again, Hornsea 1 would respond as required.”
Note the suggestion now that it was a “ simultaneous” ..failure of two generators ?18 Aug: UK Times: Interview: National Grid’s John Pettigrew —
by Rachel Millard
John Pettigrew was driving home to the Midlands two Fridays ago when he took a call from a lieutenant. It was just after ***4.53pm and the chief executive of National Grid was looking forward to seeing his family. However, the moment he answered, his weekend evaporated.
Two large power generators — the Hornsea wind farm off the coast of Yorkshire and the Little Barford gas-fired power plant in Bedfordshire — had failed simultaneously. National Grid’s frequency was dropping below the standard 50Hz to as low as 48.8Hz, knocking out 5% of the country’s power supply and causing blackouts…
https://www.ft.com/content/8b738eac-c024-11e9-89e2-41e555e96722
David Sheppard in London and Nathalie Thomas in Edinburgh AUGUST 17, 2019
National Grid’s preliminary investigation into the blackout that caused widespread disruption in England and Wales last week has raised the possibility that it was caused by the world’s largest offshore wind farm accidentally going offline.
The provisional report, which was submitted to regulators on Friday, suggests for the first time that the Hornsea offshore wind farm, which is owned and run by Denmark’s Orsted, may have tripped offline seconds before an outage at a smaller, gas-fired station.
The findings, which were relayed to the Financial Times by people briefed on the report, suggest the blackout may have been avoided if not for an error at the wind farm.
You are using words you do not understand again.Hillhater said:But they are still full of BS..... There is no way a grid with40% non synchronous generation , could withstand that scale of generation loss.
You've demonstrated it here quite a bit.Hillhater said:You are guessing at the knowledge level of someone you do not know.. ...again !![]()
https://www.telegraph.co.uk/news/2019/08/20/lightning-strike-blame-blackout-affecting-11-million-customers/An interim report by National Grid into the causes of the power cut on Friday August 9, found the lightning strike hit the network at 4.52pm. Within minutes Hornsea off-shore wind farm and Little Barford gas power station suffered a failure, but National Grid did not have sufficient levels of “backup” power to cope with the loss in supply from those generators.
The bolt of lightning triggered an off-shore wind farm and a gas power station more than 100 miles apart to “independently” go off grid in what were “almost simultaneous unexpected power losses”.
Energy experts and critics of the UK’s increasing reliance on renewable energy are warning that new infrastructure, including battery systems to store power to cope in the event of an outage, is now desperately needed, raising the prospect of soaring energy bills.
The lightning strike was one of many to hit the grid that day with strikes "routinely managed as part of normal system operations".
Professor Dieter Helm, a government adviser on the country’s energy policy, wrote online how “something fundamental has gone wrong” when a lightning strike can cause a power cut “that should never have happened in the first place”.
Explaining how key infrastructure needs a reliable supply of electricity, he said new equipment is needed to improve energy “security” on a network which is becoming “fragile” because it is relying on more “intermittent renewable energy”.
Yep. Sad that we have to wait for the dead-ender ignorati to die off before we can make progress, but c'est la vie.ZeroEm said:We are more attuned to looking back to see what happened than being aware of it happening at the time. I do see food shortages and instability. See the establishment fighting to maintain the status quo. They started losing their grip 10 years ago, but fighting hard to keep it maybe why trump was elected! We are changing but to slow, it should speed up with the last generation dying off.
Yep. Tesla is now a mature, successful company, and like all such companies, they are starting to attract bottom feeding lawyers. Such lawyers go where the money is.TheBeastie said:On other news on green energy, 7 Wall-Mart stores have caught fire from Tesla's solar panel installations and Wall-Mart is suing Tesla to fix the damage and remove ALL the Tesla solar panel installations from its 240 Wall-Mart store locations due to a breach of contract.
