Background: I've been trying to understand how winding count, current, and voltage affect low speed hill climbing ability in DD hub motors. I've been focusing on torque because a bike at a standstill would seem to be an extreme case. If the bike has enough torque to start up a hill, the ability to feed power and shed heat will determine the equilibrium speed up the hill. I want to dabble in hub motors, but want to do so in an educated way; I have a BB drive currently but just bought a 9x7 that was on sale at Cycle9 because... well, because I could. Seemed like a good place to start experimenting.
Dilemma: I quote the following from ebikes.ca (who I think everyone recognizes as leaders in the ebikes area):
Contrast that with a recent posting on a thread here that compared 9c motors of different windings in a table of torque and speed vs count:
http://endless-sphere.com/forums/viewtopic.php?f=31&t=24515&start=45#p355632
I would have concluded that both speed and torque are strong functions of winding count, which seems to be contrary to the information on the ebikes.ca web site. In fact, they are acting exactly like gears; the torque goes up in direct proportion to the winding count and the speed, down. I have assumes it was max torque in the table I cited but maybe not. I suppose it could be the torque at max speed although I don't know why you would want to know, except to calculate power required.
Any insight is appreciated.
Is there a tradeoff between speed and torque?
No, there is a frequent misconception that the hub motor windings are similar to gears in a conventional drive chain, and that as you go to a lower speed you get more torque or visa versa. This is generally untrue. If you were to increase the speed of your motor by increasing the battery voltage, then both the speed and the torque of the motor go up. If you increase the speed instead by leaving the voltage the same and going to a lower winding count motor, then you do get more torque at higher speeds, but ever so slightly less torque off the line because of secondary losses in the wiring and controller.
