DrkAngel
1 GW
At minimum you need a studded front tire!
Better is two.
If tires not identical, then the front should be the better one.
It is possible to make your own "homemade" studded tires.
During the worst ... I lower my seat so I can "ski" my feet.
For extra torque, deep snow, slush etc., I will be running a 33V battery with reduced gearing.
Larger Ah battery at reduced voltage, should help minimize voltage sag due to cold.
The eZip removable battery pack allows me to keep battery warm till used.
I have considered a battery warmer but my shorter trips don't require much time in the cold.
Better is two.
