its_me_jason
- Joined
- Mar 8, 2013
- Messages
- 77
1 noits_me_jason said:1--is it really important to use silicon wire?
2--what type of wire are you using?
3--Where do you get it?
4--at what cost?[/color]
bowlofsalad said:This might be a useful chart.
on an e-bike/trike/whatever, everything moves! Stranded wire should be your only choice. Where things flex more you should use more flexible wire (more strands)its_me_jason said:Solid vs stranded wire!
what's your choice and why?
ddk said:bowlofsalad said:This might be a useful chart.
*Insulation material and thickness is what determines the maximum Voltage handling of cable, whereas silicon is such an overkill for an e-bike.
But silicon is very flexible... but only if the cable is too.
Kingfish said:
- As a rule, I use this conservative chart by PowerStream for current capacity and for calculations.
- I like EP Buddy & TinnedMarineWire.com for hefty wire needs. I don't use HK because the domestic warehouse doesn't always carry what I need when I need it. Sometimes I use my Local Electronics Store when I've got to have it Now(); :lol:
- I use the noodley wire when it needs flexibility.
- Highest strands for flexibility, and AC conductivity.
- Solid wire is used only for Trace-Beefing, and I use 12- or 10-AWG.
- 12-AWG is the smallest I use, and that's for Phase Wiring through the Motor Axial.
- Battery interconnections and Phase Wiring from the Controller toward the Motor are 10-AWG.
- Pigtails to separate battery assemblies & to supply power to the Controllers are 8-AWG.
- The Main Battery Supply Bus is marine-grade 6-AWG and runs the length of my top-tube with a 6mm barrel connector for the trailer harness.
- All 8-AWG pigtails are swaged to the Main bus using Copper tubing.
- Every power connector is a barrel-type: 4mm for individual battery and for Phase Wires, 5mm for pigtails & controllers, and 6 mm for the Trailer & high-current charging tap.
Perhaps all the wire gauge & connections are overkill... although I no longer have lags![]()
Cheers! KF
