Hi there.
I wanted to try seek clarification on something before I do something stupid!
Im wanting to wire up a USB outlet onto my ebike but just want to make sure I do it the correct way.
Ive purchased one of these from Ebay http://www.ebay.com/itm/DC-DC-8-48V...er-supply-buck-step-down-module-/350859745532
The battery im using is 36v running 15Amp continuos. not sure what the peak would be?
My question is this. Should I run something like this http://andersonpower.com.au/lead-double-anderson-sb50-extension-standard-duty-p-453.html directly from the battery, one connector would go to the motor controller, the other to the step down module. I would use standard anderson powerpoles for all the other connections. output of the step down module would be connected directly to a stripped USB cable. Or is there a smarter way to do this?
Also, would Cable that is Twinflex 2.5mm2 (rated to 25Amp) be suitable for this setup? or should I go to 2x4mm2 cable? (rated to 42Amp) for a better safety margin
Thanks for any help
dave
Thanks for any help
dave
