Wiring scheme pinou Kugoo G2 Pro
Snabo
Hello, I buyed from china controler and display as on a picture, and now I need pinout from controller for rx, tx, dms pins …i dont have cable from display to controller so I must make one…thank you
google for details of this.. and include the keyword 'pinout'#
Not 100% confident but generally Black wire - ground,
Red wire - battery voltage
Blue wire - lock/on (shorted to red/battery voltage to turn on the controller. )
- with a 6pin to 5 pin cable the internal short could be the red/blue??
That leaves 2-3 remaining Tx, Rx,(yellow/green or visa-versa) and perhaps a brake sensor input(white)? - none of which would be damaged by 'suck n see' testing..
if your wires are of different colours???
Ok so here u go, little reverse eng. happen here
red - POWER
purple - RXD
yellow - TXD
black - GND
orange - DMS
this is colors from controller
julet and higo look very similar...
Julet connection colour codes/pinout
If Higo.bafang perhaps
its most odd your missing the connecting cable? generally controllers and the corresponding display are a pair and often fail to work when sourced separately, not always but enough to warrant buying together if needed.
I solved this, it works very well, noisy sound from motor but it is what it is … 2 problems, no speed on display and error 15, probably because of brakes but i didnt see any line for brakes…this motor is with hall sensor but controller is without hall support so i dont know, is there any way controller can calculate kmh from load/current or sth…
