Working with thick welded aluminum busbars?
thoroughbred
virginia
I'm working with some ev prismatic cells joined with busbars. It looks like there is a thick pad used for each terminal upon which a busbar is attached by laser welding.
I don't have a mill so my first attempt to separate cells was by drilling around the circular welded area. The hole saw i tried was too aggressive. Any other techniques I should consider?
A Dremel tool with a diamond cutting wheel might work. However, be sure not to short anything with the sparks and flying metal particles.
:D :bolt:
