jeff peterson
- Joined
- Dec 14, 2007
- Messages
- 65
First a little back ground... Plan: build a 3 wheel bike to carry passangers or cargo around a small flat road beach town. I bought a cheap ebay rickshaw trike. [$320 delivered] I got what I paid for. Next I bought an unknown brand 48 volt gearless 500 watt front hub motor kit and 4 SLA 20 hr batteries. I put it all together and was surprised how well it worked for the first week. After that the rickshaw kinda died one part after another and the motors spokes broke do to the lateral strain while turning. But I learned a bit and was hooked on the idea.
I have now bought a Workman 3 speed Stretch Mover Trike with HD rear rims, kevlar tires and front drum brake. This is one heavy, well built trike, with rear spokes about the diameter of my thumb! Next I added a Curry 450w 24v chain drive bike motor. Mounted the Curry motor to the frame and connected the chain to the 7/8" axel via an additional 20 tooth free wheel sprocket. The speed of the trike seems to be about 15 mph on the flats without pedaling. FYI - you can only pedal about 12mph in 3rd gear. I have the same batteries as before, but they are now set up at 24v 40hr
I had 2 thoughts. 1- connect the 450 watt motor to the 3 spd hub and connecting the pedals to the rear axel via the 20 tooth free wheel sprocket. 2- adding a second 450 watt motor to the drive system. Please understand, 15 mph is fast enough. But I want to be able to haul concrete, mulch, sand.... from the local stores, or a normal grocery run, or recycle run or two passengers. Not at the same time of course, but maybe as far as 5 miles. At this time the motor connected directly to the axel can do all this. But it's often straining during start up and when crossing the canal bridge as you would expect. Moving forward, I'm hoping to reduce some of the motor strain as this can not be good for it. Plus if the motor was in first gear I could help it more via pedaling.
Questions: Will 2 motors use a lot more power on the flats than one? Is there a best way to connect them? Will a 3 spd hub handle 450 watts? What about 900 watts? Am I asking to much from an etrike?
