Ebikeman said:
Ok NeilP for your thoughts, but that does not help me as to what values to enter now. Do I enter the.....
Anyone who gives you a direct and concrete answer does not know what they are talking about
Listen bro... these board blanks come from a dozen factories and they are populated by 100 different random Chinese guys and then sold to 200 more guys like me who may or may not change this or that. There is no answer to your question - and even if there were a correct answer it would be tentative (at best) and subject to change at any time.
So... Set your current limit to 20A DC
Set your CA up with the correct shunt info (Make sure it is CORRECT!)
Go load the bike down on a steep hill
Did you see 10A? 20A 40?
This will give you the current multiplication factor.
Now - set the LVC to something like 30V
Hook up your controller to a variable supply (or hook in and out packs as best you can to vary voltage)
Keep turning down the voltage until the controller cuts out
What voltage was it? 30V? some other value?
You can back-calculate any R12 mods by the difference between these two values... or you can just open the controller up and directly measure the R12 value.
This is super DIY territory - dont let the professionalism of this programming software lull you into thinking that this is some how "explored territory". Since they came on the scene several years back the Infioneon type controllers have been in a constant state of flux - changing monthly - and then changing even more as feedback from customers, guys like me, guys like cell man, guys like Lyen, guys like Keywin... feed back what needs changing etc.
Experimentation and successive approximation FTW... and remember... confirm your shunt value with a constant current source if you can. Just because it is written on the controller does not mean that it is correct (coming from a guy who manufactures controllers and writes shunt values on cases)
-methods
