XTreme Green Sentinel PMV - 3 wheeled Chariot
Dacflyer
Fayetteville , NC
Just poking in the dark here, Does anyone happen to have any of the electronic modules for this unit ? I think the module that sends data to the dash panel has died on mine, The panel lights up, but no data is displayed. Battery volts = 0 , Amps- 199.9 , Speed =0 Cell volts - 0
Would be nice if i had a way to connect to the CAN BUS system and see what info there is. Not sure if it lost programming or if module is bad.
I did get the motor rebuilt and working. Now the dash panel is out,.
was hoping to get it fixed up to sell..
Most of the time communications failures are caused by wiring problems--either a wire has broken (usually right at the point it enters the contact in the connector) or other connection problem exists (wire broken right at solder pad on PCB). Sometimes it's a transciever chip failure, usually on the transmission end.
I have checked all cables and connections,,Not able to check the boards themselves, they are potted..
I wish there was a way to connect to the CAN BUS and see what there is to see.. but without the program, There is nothing i can do.
BUMP... Still hoping to finding info...
or can anyone recommend something that will replace the dash board with something that will work ?
