Based on some of the failure modes posted for their controllers, they ignore a number of mechanical issues, and/or have less than perfect QC. :/But how 3shul can ignore such a small but important thing is beyond me..
Hey! That's a new LH brake pump! Specs please, piston diameter and where to get it. I need to do something about my rear brake, it's almost nonexistent..
If you don't use your rear disc brake do you simply rely on passive regen like engine braking on a 4t bike ? If so how much regen do you run ? Otherwise do you have a lever for regen braking ? A friend of mine did that on his Talaria and he loved it and was using it more than his normal brake.It's a formula brake pump and hose for stark varg. I don't know specs, I just took a chance thinking it is probably close to what I want.
I planned to get a brembo, but I got this one for cheap from an owner that changed to brembo.
Those are supposed to be better, but as I rarely use the mechanical rear brake it is probably good enough for me.
Can the fuse fall out on heavy bumps?... also a fuse for the dc dc...
I like to salvage 12v relays from scrap microwaves, they're not too big will still being sufficiently overpowered for all my e-motorcycle accessoriesI had a 24v relay that I borrowed from the ventilation, but it turned on when I tried it on a 12v battery. I now found a 12v relay in the heating system I could borrow..
It's actually a specified as a DC current relay, according to that. However, the voltages for the contacts are specified as AC, which means they may not be far enough apart at break to actually break a high current DC flow since there's no zero crossing.At first glance it looks like it is rated for 16A, but it seems like it is just for AC..
If you watch enough Munro motor tear downs you see all sorts of interesting EV motor cooling systems, as per usual Lucid seems to have the most (over?) engineered version, interesting watch if you have a few min to spare.I have seen cooled rotors in ev motors, but not oil spray on the windings.
I have been considering potting or just pour a little oil in the motor and let it do it's own spraying
Oil would be easy, and would find its way everywhere I suppose.
I guess potting would be effective on the end turns, but would it help the stator or the windings in the stator?
If you fill in oil to cool this engine, then there seems to be one contradiction.If you watch enough Munro motor tear downs you see all sorts of interesting EV motor cooling systems, as per usual Lucid seems to have the most (over?) engineered version, interesting watch if you have a few min to spare.
I think the reason for the sprayers and dry sump sorta pump out system is too much oil means viscous drag. So like if you put in enough oil so the level doesn't touch or just barely touches the rotor obviously it will cool the parts under oil well and in a road vehicle maybe not much else but on a dirtbike you figure there is going to be some splashing onto the rotor which will be flung onto the stator instantly and some oil will always stay in the windings from capillary action to help them conduct to each other and to the stator. But critically the oil once stay between the rotor and stator generating viscous drag and even more heat. I've always thought DOT 5 brake fluid would be an good choice, it's just silicone oil so pretty inert and it's very very thin viscosity wise. Also probably decent material compatibility.
I think potting would help the windings in the slots more than the end turns, unless the winding is already heavily varnished, which is kinda like topical potting. All those round wires just touch each other here and there but filled with potting you replace all that air with something vastly more thermally conductive. I think ideally this is done with very very thin potting compound and/or under vacuum to get all the bubbles out and fully saturate it.
Another thought that may buy you just a degree or two is a coolant additive, I kinda recall seeing some tests of them and them working but probably work much better in an ICE engine due to larger temperature gradients.
I don't think it will really work like this, first, the idea is to fling the oil off the rotor so the rotor will only get as warm as the oil that's picked up, heat won't conduct from the windings to the rotor. Second the rotor is already as hot as that anyway since it's inside with no way to conduct heat other than through the air (ok technically some small amount though the shaft I guess) which is doing the same thing as the oil but worse at moving heat to the water cooled case. And 3rd the rotor is also being heated by magnetic forces and you can overheat the magnets just from that so in some cases that oil may be cooling the rotor. And forth of course removing heat more efficiently in total will keep everything cooler since inside of the motor is more or less one thermal system.If you fill in oil to cool this engine, then there seems to be one contradiction.
On the one hand, yes - the temperature from the stator windings will be transferred to the rotor by spraying with oil and the rotor will take part of the stator temperature, but! The varnish stator winding can withstand a higher temperature than the neodymium magnets of the rotor, hence the question - do we need to heat the magnets so much, because it is better to transfer the temperature from the stator to the external environment, but not the internal one?
And in this case, it is better to fill the stator windings with a heat-conducting compound so that the windings give off the temperature to the finned motor body.
