spinningmagnets
100 TW
I have seen several "Cannondale Hooligan" builds, and I recall a similar frame that was slightly more appropriate for attaching a battery pack to the "triangle" portion of the frame. The Yooniq bicycle is from Slovakia. Aluminum, 20-inch wheels (which allows a wide variety of tires). It also has the option of an eccentric bottom bracket (an eccentric allows a bike to have an IGH or single-speed with no chain tensioner, also a belt-drive instead of chain with no tensioner).
I like it for a "grab and throw" bike which can be put in a car trunk or the back of a van easily, or carried up and down stairs. I would add QD nuts onto the front axle. the combination of QD axle-nuts and a disc brake means that the front wheel can be removed and re-attached very fast and quite easily with no tools.
Luna Cycle just built up a Cannondale Hooligan with a BBS02, and then immediately upgraded to a BBSHD, but...even though they were able to squeeze a shark pack onto the frame, the Yooniq could easily accept a larger dolphin pack, yes?
