I'm cycling my packs before I put them on my new bike. Most every 6S 5AH Turnigy 20C is giving me 4.7AH from 4.15V-3.5V. One cell ended up at 4.1AH and has been replaced, but the rest are fine. Probably 50+ cycles on it, lots of 1.5C bulk charging, minimal balancing, quite substantial monitoring. The cells average 3-4 mOhm internal resistance, which is roughly 1mOhm higher than fresh cells.
What's really interesting, is that my bother built his pack the same time I did, probably has <10 cycles on it, but has less capacity. He never monitors it, never balanced it, and stores it at whatever SOC it was at when he was done with it. I just started cycling his packs, and so far 4 of them were evenly discharged down to 4.5Ah. Very few cycles, no bad cells, all with 2-3mOhm internal resistance, but lower capacity than my 'used' cells. One of his packs even had a REALLY weak cell that showed 17mOhm resistance! I'm guessing the remaining packs will show more issues.
The difference? I bulk charge my pack before use, putting only enough energy in so that I come back home around 3.85V/cell. Stored mostly around 3.8-3.9V/cell and generally shallow discharges. My brother had his bike sit in the shed over winter, at 100% SOC, when ambients were below freezing.
http://www.youtube.com/watch?v=OoiSIlL6bOs&feature=youtu.be
I thought it was interesting that the one 'bad' cell in this pack was binned as lower capacity from the factory. Are most common failures due to these lower capacity cells?
