danielnilsson9 said:jayteee said:Yep , Display still gave constant crazy readings and the motor just being intermittent. I tried giving it full power from a stop , it struggled so hard , it just stopped working for a second or 2 .
Ok, I got no clue really. Same thing if you do not plug in the programming cable in your phone but just leave it connected and run without display?
Ok . I've tried without display . Same symptoms . And then I suspected if the battery wouldn't be able to take the higher amperage. Which couldn't be the case as it's a 40amp peak.
